Rear lexan instal
I am replacing my 6 Cup rear lexan window. I have the new lexan, gasket, and trim piece.
My question is: has anyone glued these in themselves and if so what is the procedure ? I was going to call an auto glass guy if it came to it.
not sure what they use 3m probably makes something. shouldnt be a difficult process maybe a heat gun and a putty knife to get the old one out and then make sure to clean up all the old goo. A glass shop can probably recomend something to use to install the new one with.
chris
chris
andy did you know the rear lexan was warped on purpose? i was told this was a trick of the time to reduce vibration and air flow over the rear window... just so you know ...
