Porsche Cup Cars
997 CUP coolant pipe failure
Old 10-15-2023, 02:41 PM
Ecosse911
Ecosse911's Avatar
Default 997 CUP coolant pipe failure
https://rennlist.com/forums/porsche-...n-997-cup.html
I am trying to conclude if the coolant pipe design / adhesive is common between road GT3’s and Cups. There is a ton of info on GT3’s but very little specific info on Cup cars likely due to lesser build quantities. I am specifically interested in the 2nd Gen 3.8 which I have read may differ from the 1st gen as the adhesive was improved. The only info I found is attached which is from 2018.
My questions
1. Is the coolant line design common between 7.2 GT3 and 7.2 GT3 Cup
2. Is it recommended to have Cup coolant line modified, weld or pin
3. Do HPDE or race org require the modification
Old 10-16-2023, 06:22 PM
Ecosse911
Ecosse911's Avatar
Well at over a hundred views and zero responses I will assume that I am over thinking this one.... not an issue on 7.2 Cups... unless someone says otherwise
Old 10-17-2023, 08:17 AM
J. Kid
J. Kid's Avatar
My 997.1 cup had a failure in the epoxy after a motorsport rebuild. Caught before catastrophic failure. I had the motor pulled and welded in sharkwerks couplers.
Old 10-17-2023, 10:30 PM
Ed@Demonspeed
Basic Sponsor
Ed@Demonspeed's Avatar
Yes, these parts and the adhesive is in common.
Very few cups has suffered this fate. I would more attribute this to the lack of heat cycles for the adhesive. While a street car may see 500 heat cycles of the engine in a year it would take more like 5 to 10 years for a race car to see that many heat cycles.
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
Old 10-17-2023, 10:52 PM
Marv
Marv's Avatar
Received 1,013 Likes on 539 Posts
My questions
I personally would find the use of any adhesive suspect. My preference is welding. I can’t imagine why this wasn’t done in the first place.
I can’t help you with questions 1 and 2.
Old 11-10-2023, 12:03 AM
Ecosse911
Ecosse911's Avatar
I have been researching pinning the lines as I plan to do it myself. I stumbled on a comment by Sharkwerks that the cup cars are different and have a threaded connection (see first paragraph in the screenshot)
https://www.sharkwerks.com/tech-arti...gt2-turbo-cars
Old 11-10-2023, 08:27 AM
J. Kid
J. Kid's Avatar
My 2006 cup definitely did not have a threaded connection. I saw it disassembled before the pipes were welded and was just like my 2008 street GT3 coolant pipes.
Old 11-10-2023, 11:09 AM
Ecosse911
Ecosse911's Avatar
Maybe I read the sentence out of context but if so the Sharkwerks blurb is a little misleading. The car arrives in 3 weeks and I am guessing based on your response (as well as other web based comments on 7.2 cup adhesive) it’s going to have the same bonded in slip fit extruded pipes. At least I now know how to pin the lines. It looks time consuming but not overly complex.
Quick Reply: 997 CUP coolant pipe failure
