996 Center Duct Install
Does anyone have a pic off a 996 Cup with the front bumper off and the center duct installed? I got my car without the duct and want to make sure I'm installing the two pieces correctly.
Thanks in advance,
Bob
Thanks in advance,
Bob
In front of the center radiator. Pic 4 in the link you sent. It looks like the upper, larger piece slopes down, but I can' really tell about the lower piece.
Thanks Francesco.
Bob
Thanks Francesco.
Bob
You're talking the rubber part then? This is on the upper edge of my radiator, yes, but no lower....although the partslist says a big boot type duct as seen on 996 TT etc.
Well, my (oem) bumper has no protective mesh mounting frames anymore, mesh is glued in from the inside, the bumper has been repaired lots of times with some fibreglass.......going to be changed with a carbonfiber bumper soon anyway
Well, a lower would not fit behind my bumper nor make much sense as the radiator is very close to the bumper (front/bottom), but if you can fit one, why not. I'm not quite sure if the radiator is really well located to the body as there are quite long distance tubes for mounting the radiator frame to the body. But it makes sense to me to have as much distance possible to the body and water temperatures are just fine so I will not change my running system
ob,
I'll try to get a picture of my car's center radiator pieces today or tomorrow. I have the two pieces you note installed.
Toby
Toby
