996 Cup Shock Components
So I acquired a set of 4 Sachs shocks for my '6 Cup off eBay recently. They are in desperate need of a rebuild so they will be heading to David Glenn in the near future for him to work his magic. In the meantime, I tried to order some of the component parts of the shock assembly (bump stops, spring perches, etc...) and found out once again that these cars are now viewed as "vintage" cars!! The NLA parts include:
996-343-677-90 Upper Bump Stop on Front Shock
996-343-547-90 Counter Nut on Front Shock
996-341-513-90 Rollbar Bracket (used on both front and rear shock)
999-333-677-90 Upper Bump Stop on Rear Shock
996-343-785-9A Counter Nut on Rear Shock
The upper Spring Rest used on both front and rear shocks (996-343-511-90, the retainer positioned atop the main spring) is out of stock, as is the Helper Spring (the lower 60mm spring, 996-333-537-90, H&R part ZF060-050), the small spacer bushing on the top of the rear shock just below the two counter nuts (964-333-466-85) and the 50x20 fastening clamp (999-511-118-02) for holding the rear external canister.
The NLA and some of the out-of-stock parts "could" be another opportunity for Demon Speed to shine - especially the bump stops and upper spring rest. The rollbar bracket has been NLA forever! If you have them, hold on to them!
Thought I would pass this info along for those of us clinging to our 996 Cups.
Toby
Toby
I think 996.343.511.90 is a dealer item and sells for about $70: https://www.sonnenporscheoemparts.co...at-99634351190
TBP
The seay brackets that thread on are actually 993 parts and are no longer made. Check with tarrett they make aftermarket pieces. Spring hats should be available from aftermarket supplier as well.
Basic Sponsor
You could also try calling Angelo at Anze. They are making more and more of these parts. He and I tried to get something together for me to sell his parts at Demon Speed after a discussion at PRI, but he is a bit elusive.
He was also looking into the set of 3 way Sachs shocks that James at SRP had when they closed up shop and I never got back from a year ago.
Ed
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
