Red shift light stayed on
Steve- In my 930 I had a similar problem. In the GT3 I think it is called coolant regulator. I'm not sure if its a spring like in the old thermostat that can get stuck from grit / heat etc. Maybe a temperature sensor of sort if electrical...Our wire harnesses are getting old.
