380mm front rotors offsets?
Premium Sponsor
The 996 RS Homologation pdf has some of the differences in the RS to RSR upright. http://historicdb.fia.com/car/porsche-911-gt3-rs
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
All great info!! I will also add that I verified with Porsche and the 996GT3RS upright is the IDENTICAL part as the 997.1GT3 upright (steel brake version). I suspect that the Cup and RSR upright have identical (or very similar) pickup points as their ride heights are similar.
Yes Cup have 12mm lower lca attachment point becouse the race car runs lower and have bigger tires
alot of street people just buy race parts becouse it sounds cool but have not a clue what they are doing. They are making the handling worse then stock but thinking they are upgrading
Premium Sponsor
^^^ This! I also get people calling me at the shop wanting Cup ride height on street car. Each time I'd explain there's a difference in geometry and tire height but usually that's not what the caller wants to hear and they get what they want done somewhere else. None the wiser I suppose
Looking at the above, looks like my shop installed the street version, while in the end they could have gone with the RSR versions based on the spacers required to get the correct roll centers.
John, I have on the table 996RSR??? (.9E part. I have 996.341.658.9E but according PET for 996RSR it’s 996.341.157.9E) + 996GT3RS(997.1 GT3 steel, .93part) + 997.1 GT3 PCCB (.94part) + 997.1 CUP (.92 part)
ALL of them are for 996 style ABS sensor!!!
So, 996GT3RS and 997.1 GT3 steel, .93part) is absolutely the same part. On the left is 996GT3RS, on the right 997.1GT3 steel part
Those are the .95s which use the 997 ABS sensor along with the different tension bolt. Those were used on the 997.2 cars and Porsche raised the pickup point on those likely due to the fact that the rear track was wider on the 997.2s compared to the .1s. That's the only upright you could use on your car due to the new generation ABS sensor.
Willy077,
The shock bodies were cut down and the internals were rebuilt and custom valved for this application so the bodies would not extend past the bottom of the upright shock mounting points. Therefore, allowing the front driveshafts to be installed without any issues. The driveshafts have 10mm spacers as well.
