Harness belts timed out-recommendations?
Standard Schroth Cup belts have timed out so looking to replace.
Another set of Schroth Cup specific belts which seem to be purpose made for the Cup or what about Schroth Enduro or OMP WEC belts?
The Schroth Hans versions are actually 2"/3" with either 2" or 3" waist belts.
The OMP are dyneema which are low stretch and light. Not sure about that v-crotch belt fitment though.
Schroth specific would be the route Id go, always an advocate for OEM fit.
I have 3" straps now- can I assume the shoulder belts that taper from 3 to 2" will fit the Hans grooves better?
What about the 2 vs. 3" lap belts? Schroth says they are safer and fit better.
look at deist harnesses. the nice thing about them is when the time out you send them back to deist they replace everything but the hardware and recertify for about 90$ per harness.
Have never had a problem with the endurance belts. They are my number one choice. They tighten/loosen much easier than standard and the lap belt pulls are in a better position IMO.
