2008 Cayman engine ticking noise
Old 01-29-2019, 08:40 PM
natef
2nd Gear
natef's Avatar
Default 2008 Cayman engine ticking noise
Hi, Today I took delivery of my first Porsche. I was very excited until I heard it. Im not sure if its a normal ticking noise, after search through the forum, I found that many people have had similar issues. some attribute the issue to the injectors. With my limited knowledge of cars, I immediately thought it was the lifters. Anyway, I posted two videos of the noise. One of the videos is with my phone up against the air intake vent...
Can you guys check this out, let me know what you think? is this the normal Cayman engine noise or should I be concerned? Youtube links below
Thanks a lot!
https://youtu.be/yi6CTE2tWUc
https://youtu.be/Lijx-e7C-Rk
Old 01-30-2019, 10:12 AM
badabing
badabing's Avatar
I think you should be concerned. That doesn't sound good to me.
Old 01-30-2019, 10:31 AM
danschy
danschy's Avatar
Yeah, not good. When you said "ticking" I was expecting the occasional lifter noise I hear when I haven't driven mine in a while. Your noise appears more substantial, but still might be related to the valve train. It is definitely not typical and needs to be diagnosed.
Old 02-04-2019, 06:39 PM
desmotesta
desmotesta's Avatar
Received 1,957 Likes on 935 Posts
Not to alarm you but that does NOT sound good..
I haver a 157K mile cayman S and even my old tired engine doesnt sound like that
I was expecting some valve click... this is more like a rod knock..
Don't drive and have the car looked at by someone who is very familiar with Porsches.
good luck and keep us posted
Old 02-04-2019, 06:54 PM
jscott82
jscott82's Avatar
Agree with previous responses. Don't start it again, get it towed...
Old 02-04-2019, 07:18 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,580 Likes on 987 Posts
Is that noise with the serpentine belt on or off? At the risk of causing more damage, you could take the belt off and start it to see if the noise is there. If it’s not there, check the water pump or any other pulleys. I would only run the engine for 30 seconds with the belt off though.
Old 02-05-2019, 10:31 PM
desmotesta
desmotesta's Avatar
no update ??
Old 02-08-2019, 10:44 AM
JC Lacayo
JC Lacayo's Avatar
Update bump
Old 03-31-2019, 11:56 PM
PGas32
PGas32's Avatar
Old 04-13-2019, 12:53 AM
VolklGS
7th Gear
VolklGS's Avatar
I would put serious money that what you hear is a scored cylinder. Especially if it is an S and not a base model. The 3.4 S engines, unlike the base 2.7 engines, are a high risk for bore scoring as I understand it.
Listen to the attached file of a Porsche with a scored bore.... sounds similar.
I hope I am wrong.
Old 04-13-2019, 12:45 PM
RobC4sX51
RobC4sX51's Avatar
https://www.youtube.com/watch?v=LHKPqebCjpQ
I hope I am wrong.
This is in contrast to Charles Navarro’s February article in the Panorama. He said the 3.4 rarely has bore scoring, it just wears out. Page 90 under the “what is the most common engine you receive” section.
Old 04-13-2019, 12:56 PM
996AE
996AE's Avatar
Received 1,450 Likes on 956 Posts
Yep
A lot more than valve tick
Not likely belt off will change sounds
Tow truck time
Old 04-13-2019, 01:36 PM
PGas32
PGas32's Avatar
I believe a comment on the YouTube video indicated that it was a bad flywheel. It was apparently fixed and was offered for sale here and on Craigslist for a suspiciously low price. Doubt we’ll hear from the OP again
Old 04-14-2019, 02:49 AM
VolklGS
7th Gear
VolklGS's Avatar
Listening to the original video again, it seems too rapid for a the bore scored engine - at least based on the video I posted. I jumped to the bore scoring conclusion because it has been on my mind after spending too much time online looking into the issue. Was perhaps a bad flywheel as you said PGas32.
Tangent to the OP's question, RobC4sX51 you mentioned a recent Charles Navarro article that claimed that the 3.4 motor rarely suffered from bore scoring, which seems to contradict what I posted. I don't have access to the article, but thought I would check to be sure Navarro was not talking about M97 3.4 engine that goes in the Cayman S, but rather the M96 3.4 engine that was used in the first generation 996s. Because from what I have read the 996.gen1 3.4 motor was indeed less prone to bore scoring compared to the 3.6 gen2 996 engines and 3.6/3.8 gen1 M97 engines used in the 997s. That makes more sense to me. Frankly, the bore scoring issue has cooled me on the prospect of buying a Cayman S - which in all other aspects checks all the right boxes. So if I have this backwards or if there is new information on the reliability of the 3.4 M97 motors I am all ears. Thanks.
Old 04-15-2019, 04:34 AM
Charles Navarro
Charles Navarro's Avatar
Received 1,071 Likes on 557 Posts
Looking back though photos of incoming blocks, it would seem that the early 3.4 engines had more issues with cracked cylinders than scoring.
Likewise, we never see 2.5 or 2.7 engines with scored bores. 3.2s are far and few between, but cracking is more common than scoring if I were to weigh the failures.
3.6 engines we see with scoring mostly and a few cracked cylinders.
3.8 is always scored bores and right now, the most prevalent behind the 3.6 and 3.4 Cayman. I've never seen a 3.8 or 3.4 Cayman with a cracked cylinder.
Hope that helps clarify things.
Quick Reply: 2008 Cayman engine ticking noise
