Uneven tire wear
Old 09-27-2013 | 09:13 PM
Sam CS 05's Avatar
Sam CS 05
Default Uneven tire wear
I just swapped to winter tires and noticed this uneven wear on the two front all season tires. The mechanic thinks the car needs an alignment.
These wheels are a size larger (265 60 R18) than OEM wheels so my question is can the uneven wear be due to size difference?
TIA,
Sam
Old 09-28-2013 | 01:59 PM
bansasn's Avatar
bansasn
I would think so. That kind of wear only happens to me on the rear tires. My front don't do that. I rotate my rear tires once I get that. My tires size 285/35/22. 05 CTT
Old 09-28-2013 | 02:30 PM
Brit6's Avatar
Brit6
When was the last time you had a 4 wheel alignment?
What height do you ride in?
Old 09-28-2013 | 08:47 PM
Sam CS 05's Avatar
Sam CS 05
Thank you Bansasn & Brit6.
These tires are just over a year old. It seems like you both agree the issue may be related to the alignment and not the larger size of the wheels.
It's been few years (3-4) since the last alignment.
Regards,
Sam
Old 09-29-2013 | 03:32 PM
Brit6's Avatar
Brit6
Eep, 3 to 4 years???
I do mine at least once a year and normally twice (once before putting the winters on and once before putting the summers on)
Regards,
Sam
Old 09-29-2013 | 04:14 PM
dryadsdad's Avatar
dryadsdad
Team Owner
When one asks the age of the tires, the answer is usually with miles or kms.
Anyway, I agree you need an alignment. That will either fix it or reveal suspension damage.
Old 09-29-2013 | 09:22 PM
Brit6's Avatar
Brit6
Exactly you could have some worn bushings or suspension components that need replacing. I remember replacing all of mine because it was seized from our Canadian winter salt.
Old 09-30-2013 | 05:17 PM
Porsche 25th's Avatar
Porsche 25th
I think these trucks do tend to wear out front tire shoulders quickly, Audi Qs also. There is a lot of weight on them when cornering.
Old 09-30-2013 | 08:09 PM
Sam CS 05's Avatar
Sam CS 05
Thank you everyone for their input. I really appreciate your time.
In avg. I drive about 15k miles/year.
My pepper has 120k mostly HWY miles.
This is the first time I have noticed wear of this kind.
Please don't report me to CPS ( Cayenne Protective Services) for negligence ))
I know ltc is smiling
The car is scheduled for service appt soon so I'll post the findings.
Regards,
Sam
Old 10-09-2013 | 01:36 PM
pcst's Avatar
pcst
Or it could be simple as adjusting the toe setting, which is the part of alignment job.
