New 2008 GTS Owner - Having some issues looking for advice
Hi Rennlisters
I recently bought a 2008 GTS w/60k miles. Car is great, I love it. I have noticed the infamous "longer to start" now that the weather has dropped off in Mass. I did test the voltage via a generic OBD reader during crank and it does drop low but i ALSO noticed there was a P1023 code (but no CEL?).
Question: Knowing a weak battery can throw weird codes, the P1023 seems to not be one of them - could this be attributed to a weak battery or do i need to dive into the fuel system? I read a handful of threads around P1023 none seem to be rooted back to a weak battery.
As seen with others, only the first start seems to be weak. I was away for a week and it took about 10-15 seconds to start on first try but did start. If the car has even been remotely driven it seems fine on warm or hot starts.
I've only have the car a month so if it's a battery, it is what it is and I'll replace it. If it's the pump I'm inclined to go back to the dealer and try to get them to replace it.
Thanks in advance for all the help!
Received 1,160 Likes
Hi Rennlisters
Slow to crank = battery
Cranks but slow to start + P1023 = low fuel pressure most likely. Try turning the key on then off a few times to get the fuel pump to prime the rail as much as possible. If it starts easier, then the fuel pump is having trouble getting to the right pressure. Also if the car is harder to start after sitting awhile (more than 1/2 hr) then the fuel pressure might be decreasing in the rail due to a bad pump.
Ripking (01-21-2023)
I believe the Cayennes actually prime the pump when you open the driver's door, as odd as that sounds, not when you cycle the key.
There are also warnings in writeups on removing the fuel rail to either disable the pump, disconnect the battery or just don't open the driver's door while the fuel line is off.
Not sure about the 957s.
I would invest in a good CTEK charger and let it do its thing for a while. That could help you solve the problem, or at least help you rule out the battery...
I think it is a must have for any car not daily driven.
Update, so i ruled out the battery, it was changed right before i bought the car by Porsche. I definitely think it is just early signs the HPFP is dying. I'll let it sing it's swan song and change it when it crokes.
I have a 2010 with 110K on it...If it seems like the starter is struggling to turn the engine over or doesn't the first few times it may be your starter is beginingg to fail. Mine exhibited a slow crank...charged the battery and checked it several times...dealer did the same and we found that the starter was failing...
New starter($$$) and all is like new.
The V8 Porschephile
I had the exact same symptoms and went through two Moll batteries within 2-1/2 years. I finally went the route of an aftermarket AGM H8 battery and the starter problem was solved.
