911 engine into boxter?
2nd Gear
I know its been done in the Ruf 3400 s and 3600 s, but does anyone else perform this swap? If so how much does it run (ish). thanks!
Kelly Moss has their car for sale that they did this very thing with.... KellyMoss.com
I ran into a guy that did it in a half *** way at the Glen, and had a lot of trouble with the electronics.
Deman Motorsport in Nyack, NY (very close to you) has done several conversions. He uses a brand new 3.4l 996 engine from Porsche, a set of GHL headers/exhaust, and all of the factory 996 motronics software. 845-727-3070
If you decide to do this conversion take note that the wiring harness is different for a 3.4l vs a 3.6l motor. The 3.4 wiring harness is compatible with the 2.5/2.7.3.2l Boxster wiring harness (ie you don't have to change the wiring harness to do the motor swap...just swap out the Boxster ECU for the 996 unit and off you go). If you go the 3.6l route, you have 2 options: 1) kludge up some sort of modification to the harness (in which case you will have to locate the proper connectors) or 2) swap out the harness altogether. Swapping the wiring harness might not be too bad (the termination points should be the same from the doors forward) but expect to have to get creative from the doors back.
my boxster has a 3.6l 996 motor by ROOCK. they told me it is a 330hp+.
i have been driving for the last two weeks my boxster 3.6l and it is fantastic. it was a boxster s and i have found a big improvement in the performance
Modified ECU
Installation 996 3.6L Engine
Sport Headers
Sport Exhaust System
Sport Catalytic Converters
Sport Air Filter
Air Intake System
Sport Clutch
Power: Est. 340 bhp
Torque: Est. 273 ft lb.
0 - 60 mph: Est. 4.9 sec.
Top speed: 180 mph
www.roockusa.com
866-99-ROOCK
Sport Headers
Sport Air Filter
Air Intake System
Sport Clutch
Power: Est. 340 bhp
Top speed: 180 mph
www.roockusa.com
866-99-ROOCK
