Steering Wheel Airbag Jumper
This is a cross post from my 997 thread but very appropriate here as it's for a track setup:
https://rennlist.com/forums/997-foru...ag-jumper.html
Essentially need to know which wires in the steering wheel hub connector are for the airbag so I can install a resistor jumper.
Thanks for any help.
You need a 2.7ohm resistor or there abouts over the two wires.
After performing the mod, this isn't remotely correct. There are two airbag connectors, one for high speed collision and one for low speed collision (yellow and green respectively). The horn has TWO black leads and one black ground (confusing as hell). I jumped successfully and will post a DIY soon.
