ROW ECU setting. Has anyone done that?
The ROW map is different depending upon which model year you have. Also on the early 24-pin DME, it's not as easy to select maps as the later 28-pin DMEs. The differences are actually pretty miniscule, you won't notice the difference really.
[quote]Originally posted by Danno:
<strong>The ROW map is different depending upon which model year you have. Also on the early 24-pin DME, it's not as easy to select maps as the later 28-pin DMEs. The differences are actually pretty miniscule, you won't notice the difference really.</strong><hr></blockquote>
I am driving a BoxsterS and I have heard the difference is ~10HP.
Assuming you have access to a PS2. How do you set the ROW ECU?
TIA
TIA
