Hot engine starting...
Can anyone explain why it is hard to start my 930 when the car has been driven for a while? Starter and battery are fine.
Excellence Tech-Talk II has an article suggesting it is could be the rear fuel pump. Any help would be appreciative.
I noticed your post on the turbo thread but saw people were answering it like you meant it has not been run in a while which could be caused by the fuel draining back. Do you actually mean that you have trouble when it is hot. If this is the case I think a probable culprit is the fuel mixture being off.
I think ( anybody else please help because I am working on old memories) That hard hot starts means too rich. I think a bad warmup regulator can cause this condition.
Hope this triggers some additional thoughts or confirmations.
Bob
87 930
Bob
87 930
