2nd oil cooler
looking for 2nd oil cooler to fit into a 964
LEFT front fender, where the stock condensor sat. Either part #'s, or Co. name
thanks
Jerry
thanks
Jerry
RL Technical Advisor
Hi Jerry:
We have 2 options that we use here:
Porsche factory RSR cooler available from Porsche Motorsports
Aftermarket item like Cargraphic's cooler.
Both work very well but the RSR ones have been more expensive with all the lines, brackets and the cooler, itself.
Having that left side cooler really does the job, though.
Has anyone (other than the factory) installed an oil cooler behind a widebody rear duct? The oil lines are right there, seems like it would be fairly simple to plumb it in. I've thought about this in addition to the late-model carrera cooler I have in the front.
Lifetime Member
Lifetime Member
It's slightly off topic but I see that Kokeln has an oil cooler that replaces the pre-964 fender cooler with one that is %300 larger. Anyone tried this? My '86 3.4L runs a little hot at the track track.
-Chris http://www.lindseyracing.com/911eng3.htm
I guess my question follows along the same lines as Thom's...Can I remove the right rear blower motor in the C2 turbo and put an auxillary oil cooler in the same space (in that wheel well)?
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Autometrics from Charlseton, SC. came thru.
Oil cooler mount part # 993.207.415.80
Lft front oil cooler # 964.207.220.02
rt front oil cooler # 964.207.220.01
They had all airoquipe fittings & hose.
Installed very nice.
thanks, gordon.
thanks, gordon.
