Need advice on track day brakes..
Originally Posted by Steve Weiner-Rennsport Systems
Hi Jim:
GTP's use Porsche TT OEM rotors and there is not a slotted, direct replacement option on those. The front hats were specifically made for the less-costly 993 TT front rotor and the rear uses the TT OEM ones to retain the E-brake.
I do slotted rotors (Alcon) in that size but they are NOT cheap since they are full-floating and require different hats/hardware.
RL Technical Advisor
H iCarm:
The AP or Alcon slotted rotors run $ 1850/pr (floating or bolted) on the front. Rears are not available in that size and you'd lose the E-brake if you wanted a custom setup.
Cooling is critical when using these smaller rotors (305mm) on the track with these heavy cars so I'd also recommend that you install a pair of GT-3 Cup air deflectors on the front A-arms. You'll need to do some modifications to make them fit, but they help reduce brake temps.
H iCarm:
Originally Posted by cavlino
Steve thanks for the reply. I have the combo air duct fog light setup on the car but I have not run duct work to the rotors yet ... The GT-3 Cup air deflectors sounds like a very good idea. The price on the slotted rotors is a bit more then I was thinking but you did warn me
. Would I be able to use the GTP setup on my car with 17 inch rims and if so can you let me know the cost of those?
Indeed, these pro-grade racing rotors are NOT cheap, compared to OEM ones, but the quality/longevity is in a different league altogether. No comparison.
GTP brakes will fit a 17" wheel with no problem and they are really a better solution due to much improved thermal dissipation capacity. In the long run, you'd be much happier.
PM'ing you the numbers.
Cooling is Critical,....
PM'ing you the numbers.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
