RS sway bar
Technical Specialist
Lifetime Member
Lifetime Member
So what are the benefits for me changing to RS sway bar ?
I will bring the car to a track day in early Mar, afterwards I might have a better idea of what I am looking for ? Actually at this moment, I have no clue of what I want !!! Just some friends recommend me of the changes, they said it would ehance the car's respond Plus more precise handling.....Thanks
Lifetime Member
Lifetime Member
Ed,
While you can certainly do some mods prior to going to the track, my recommendation would be go to the track first with your 965 as-is. You'd be amazed at how competent Porsche's are on the track right out of the box. If you've never driven at the track, your stock suspension should do you fine for your first 10-15 events. When you're ready to upgrade, look at changing your suspension as a whole system, that is, consider shocks, springs, and sway bars. At some point, you'll want a second set of wheels to mount track-only R compound tires.
Thanks for your recommendation Bill . I will go to the track as is for I already have a set of Gambella / H&R suspension. I think for the moment is more than enough.....
