Carrera Cams - SC Cams ?
RL Technical Advisor
Yessir, they are.
Bear in mind that this cams performs differently based on how the valve timing is set.
Other good cams for a modified 3.3 Turbo are the 964 ones, depending on what you want.
The SC cams provide improved low-end and mid range and the 964 cams have a bit better mid and top end power.
Both are much better than the 930 cams.
PT:
SC cams have a LOT of flexibility,....you can set them at .9-1.1mm or 1.4-1.7mm to shift the power around a bit.
D:
No machining of 930 pistons are required as the pistons are a flat top design and these cams have modest lift and duration.
D:
All,
Thanks for all the info. Just purchased a set of low mile Carrera cams and they are already on their way to WebCam for the drive installation.
