what shocks to use with H&R springs?
i just put a set of H&R springs on my 2001 996 C4 and i'm wondering what the correct shocks are to use with these? i think it's the bilstein sport shocks, but i'm not 100% sure. here's how it looks:
thanks steve. i was thinking of koni, they make a sport shock, but i'll go for the bilstein heavy duty. will this make a substantial difference in the stiffness of the suspension? will it help with bottoming out?
another question:
is it normal for springs to have to settle in or shift in their mounts in the first few hundred miles? last night i heard a loud sound from the right rear wheel area as i rolled through a gas station. it sounded like the spring shifted in its mount. i checked out the wheel area and everything looked fine and the car drove fine.
another question:
IMHO, the Bilsteins are far superior to the Koni's. We will no longer sell nor install those.
Between the H&R's and the Bilstein, you will like the changes. Bottoming should NOT be a problem unless the ride height is set too low.
If the springs were not installed correctly, they can shift and move in the spring seats.
