Mark this thread as Unsold
Work Brombacher Wheels
#31
Category: Accessories
Price (no $ sign please): $2800
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 964, 986, 993, 996
Location (Region): NorthEast
Item Condition: Used
#32
#33
How did you measure the width? It should be from tire bead across to other tire bead area. Or if you want to convert to the ET measure from the very outside edge of the outer rim to the very further most opposing inner rim and divide that number 2 to establish the center line of the wheel. So if it is 9" from outer edge of one rim to the opposing outer edge the measurement is 4.5". So if the actual measurement is 6.75" you subtract 4.5 and get 2
.25" and then each inch is roughly 24mm -- 48 + 6mm = 54mm ET hope this helps. jdorociak@gmail.com. Jim
#34
someone with a 964 needs to buy these already. they look sick on 964s!!!
