Panamera 2010-Current
Panamera S e-Hybrid fault
Old 04-05-2019 | 09:48 AM
Dr-Panamera's Avatar
Dr-Panamera
Default Interesting, same issue last month
Thanks for the update I have a 2015 with 18,500 miles.
A month ago I put the car in park, ignition on, ran into town hall and when I got back got the Hybrid system failure. Porsche had the car for a week and did not have a clue.
It has been working since but now, no matter how I charge it, I only get 8 miles?? Its going back to the dealer next week.
Also, I was traveling earlier this week, the car had 8 miles of range when I parked it and the next morning it had 3 ? So, my guess is a short somewhere in tje high voltage battery.
Originally Posted by poompuridet
i got this problem fixed, my dealer took hybrid battery out and replace battery housing case due to recalls and update hybrid system software, now 2weeks + later i have no problem with my car - happy
Old 04-05-2019 | 01:01 PM
DogWood's Avatar
DogWood
that sounds more like a bad cell, but hopefully it's nothing too bad, good luck
Old 04-07-2019 | 12:28 PM
Stephane Couleru's Avatar
Stephane Couleru
2nd Gear
I got the same ppm 5 month ago.
They changed the 12v battery. 1kCHF...
Old 04-07-2019 | 12:32 PM
Stephane Couleru
2nd Gear
not covered by warranty
Old 04-28-2021 | 05:04 AM
Luis Torres's Avatar
Luis Torres
6th Gear
Hello friends,
Just got my second hand first Panamera e-hybrid and after being in e-charge for a while, I parked at home and I got this error message too. The front fan started going wild like it was overheating.
I turned off the car and after a few minutes it's all fine.
Do you guys figure it out why this happens?
Many thanks
Old 10-12-2021 | 08:21 PM
Alex400's Avatar
Alex400
6th Gear
really? I have same error and voltage of the battery in the back was less than 12v. You mean that 12v battery?
All electric systems seemed to work fine. Incl headlights etc.
Old 10-13-2021 | 03:16 AM
Alex400's Avatar
Alex400
6th Gear
Originally Posted by Luis Torres
Hello friends,
Many thanks
did you diagnosed your problem?
Old 10-13-2021 | 03:30 AM
Luis Torres
6th Gear
Well, never happen again.
Old 10-13-2021 | 03:51 AM
Alex400's Avatar
Alex400
6th Gear
I also got this error P0610 Control Module Vehicle Options Error. But just like the hybrid error seems to be like a general error.
My battery was low as well so replacing the 12v battery might be worth trying.
Old 10-13-2021 | 03:57 AM
Alex400's Avatar
Alex400
6th Gear
Got the e-Hybrid for over 6 months and put 4000miles on it. Have no problem with it until 3 days ago I went in to start my car and the car won't start up and it display a hybrid failure icon and say "Park Vehicle Safely" and the car won't start up. Anyone found this issue?
What was the solution in your case?
Old 04-11-2022 | 06:58 PM
SDIMECHANIC's Avatar
SDIMECHANIC
Default 2020 Panamera 4S Hybrid E-Hybrid Sport
we had the same message at 30,000 miles, two dealers have had the car for a total of 9 weeks.
after 9 weeks we finally got an answer, high voltage battery cooling system leak, damaged the high voltage battery.
waiting porsche Germany to authorize replacement.
By the way, the system has two types of warning one will say in yellow: safe to drive. You are ok to drive. In red, park safely means do not drive the car, stop get out and call a tow truck.
Old 11-07-2022 | 05:22 PM
AhmerM's Avatar
AhmerM
2nd Gear
Default Panamera hybrid 2014 won't start
Hi. New to this forum. Just bought my 1st panamera 2015 se hybrid. Love the drive. Apart from that it's just been a month and the car won't start. Wife told me that my 5yr was sitting in the car with ignition on and now it's showing hybrid sign with "Park vehicle safely. Image attached. All functions are working. The boot won't close now. Feels like the 12v battery has also drained while attempting to start.
I don't have the EV charger, im trying to borrow one to check if it will fix after the hybrid battery gets some juice. Any help from members is appreciated.
Regards
Old 11-10-2022 | 12:14 AM
amphicar770's Avatar
amphicar770
If your 12v battery is drained, even if HV is fully charged, you will get all sorts of codes. You need to fully charge the 12v battery before anything else. The hybrid charger does not charge the 12v battery (in trunk).
Old 11-10-2022 | 11:01 AM
orca15's Avatar
orca15
I don't understand this - the HV battery does charge the 12V battery, so why wouldn't charging the HV battery (indirectly) solve his problem? Unless the 12V is just dead...
Old 11-10-2022 | 12:27 PM
cbwinters01's Avatar
cbwinters01
Orca,I think you are right, but I've also been exploring that same question with my '16 pseh when i got a low battery warning while using the piwis last weekend. It will be good to know the final answer to this.
looking through the manuals, and everything that i can find online, it appears to me that the high voltage battery does charge the 12v battery, but only when the car is completely started in electric mode (i.e. if you put it into gear, it would drive). It appears that if the ignition is only 'on' (i.e. not driveable), such as when using the piwis, the 12v battery will be drained...
Quick Reply: Panamera S e-Hybrid fault
