Panamera 2010-Current
Aux BT and iPhone
Old 07-10-2015, 12:56 AM
TGED
TGED's Avatar
Yes, on my order list, it says Porsche Online Service. When the car arrived, the factory window sticker sheet says Porsche Car Connect, Porsche uses both descriptions interchangeably. I know I only got AHA and nothing else.
Old 07-10-2015, 03:04 AM
ELMEL
ELMEL's Avatar
Car Connect and Online Services are two entirely different things. It seems like someone has convinced you that they're interchangeable terms, but they're not. I have both. Car Connect allows you to remotely gather information, execute a few commands, set geo and speed fencing, and a few other things, all over the air from a remote smartphone far away from the car. Online Services simply integrates Aha Radio from a cord-connected smartphone to play content through the PCM. Check the links I posted. It'll all make sense if you go look.
FWIW, if you think you have Car Connect, the only evidence you'll see in the car is through the TFT display behind the steering wheel. You won't see anything in the PCM like you will with Online Services.
Quick Reply: Aux BT and iPhone
