Panamera 2010-Current
Burmester = Not Streaming Bluetooth Audio?
Old Sep 4, 2012 | 11:11 AM
keithos27's Avatar
keithos27
Default Burmester = Not Streaming Bluetooth Audio?
Is that true? I heard that Bose allows this, but if you upgrade to Burmester you lose BT audio streaming functionality. Can someone please confirm?
Old Sep 4, 2012 | 10:05 PM
TGED's Avatar
TGED
I never use BT for audio, the BT format was originally designed for speech. Use your USB connection, you will get much better sound quality.
Old Sep 4, 2012 | 10:13 PM
keithos27's Avatar
keithos27
Thanks for the response TGED. I understand where you're coming from... was just curious if that is indeed true (no BT audio with Burmester)? Can you confirm yay or nay? Thanks.
-Keith
Old Sep 5, 2012 | 09:33 AM
FSCCA's Avatar
FSCCA
Not true. I have Burmester and can stream A2DP.
Old Sep 5, 2012 | 09:41 AM
keithos27's Avatar
keithos27
Great, thank you!
Old Sep 19, 2012 | 11:29 PM
Eugene-Taiwan's Avatar
Eugene-Taiwan
+1
Old Sep 20, 2012 | 11:29 AM
keithos27's Avatar
keithos27
Thanks Eugene.
Old Sep 21, 2012 | 08:37 PM
pcar_finally's Avatar
pcar_finally
I was able to do A2DP with the Burmester I tried. As others have said, though, it sounds terrible compared to the direct connection.
Old Sep 29, 2012 | 04:55 PM
Abby Normal's Avatar
Abby Normal
In Your Face, Ace
absolutely not true!
Old Oct 23, 2012 | 04:13 PM
2zero's Avatar
2zero
Not true but it has to be activated!! The default is bluetooth streaming off! I know because when I took delivery it wasn't working but the salesman knew it had to be activated.
