Headlight sprayer pump replace
I expect this to be relatively simple, but wondering if anyone here has replaced the pump for their headlight sprayer on their Panamera?
I know the pump is attached to the tank / reservoir. I assume I can access this after removing the wheel liner. Just wondering if anyone can confirm.
thank you in advance
It's not a bad job at all. remove wheel and liner. Whatever you do do not pay for the porsche pump- the same exact part is found for volvo and others. If you do a bit of research you will find it. You'll pay around 25 vs triple for Porsche part.
