Panamera coding?
One of the things I like most about BMW is the ability to customize the vehicle settings with coding apps like Bimmercode. Are there similar app offerings for Porsche that are generally recommended?
FWIW (For what it's worth)
I just talked with two Scan Tool manufacturers. (6 Oct 2025)
1. DuraMetric (in Bend Oregon)
Durametric Software, Inc.
61451 Parrell Rd
Bend, OR 97702
+1-541-388-5420
2. ICarSoft (in K St. Suite 300 N.W. Washington D.C., 20006 United States.)
Both companies stated that after 2010 it is virtually impossible to accomplish ECU coding in a Porsche Panamera.
After 2010, Porsches, and especially The Panamera's software system is set with distinct and different ID codes for all the ECU functions.
Only Porsche has those ID codes, and they are on Porsche's main server in Germany.
A PIWIS ('could') do the ECU coding if you knew/know the specific ID code (varies from one year Panamera to another) for the ECU system you want to change.
They state that the 970/971 series are particularly difficult because of all the 'luxury' systems on the Panamera.
They both suggested that if you really want a system re-coded on a Panamera...our best bet is to take it to a dealer...(ouch)
Darn...
Anyone know anything different?
Thx
I know because a colleague enabled the latent matrix headlights functionality for my Panamera using his PIWIS system.
Other diagnostic devices will severely limited in their coding functionality compared with the PIWIS system.
If you only want to read and/or clear faults or perform service interval resets, check out the Launch and OTOFIX devices.
Good luck!
Durametric said you could do as you state above with a PIWIS...but with caution.
They indicated you could 'screw some stuff up' if you didn't get that 'trial and error' coding correct?
Especially with the Panamera...do you know if the Launchx431 Pro 5 has any ECU coding functionality for a Panamera?
61451 Parrell Rd
Bend, OR 97702
+1-541-388-5420
Darn...
Thx
From the conversation I had with Duramatic...they do not claim that their scan tool will even support a 2010-2016 Panamera ECU coding!!
I would proceed with caution with any claims that they can do ECU coding on any Panamera!!!
Thx
OK...I think I have found a scan tool that can 'they say' can actually accomplish ECU coding on our Panameras.
The tool is:
Autel MaxiSys Ultra S2 Scanner, 2025 Top Intelligen Scan Diagnostic with AI, 6-in-1 VCMI2, Up of MSUltra/ MS919, Topology 3.0, Multi-Point DVI, EV Test, 48+ Service, ECU program
Full ECU Coding and Adaptation support for Porsche. Performs online coding, module initialization, and advanced service resets. Includes the VCMI (Vehicle Communication and Measurement Interface) for more stable communication with European vehicles. Excellent for high-end and performance vehicles like Porsche, BMW, Audi, Mercedes, etc. Ideal for shops and advanced technicians.OK.. that is the (sort of) good news.
The BAD news..???
These units sell for about $5700.00
Yes..you read that correct... $5700 frippin dollars!!!
Jeezzz
No thanks...
The tool is:
The BAD news..???
Jeezzz
No thanks...
How about a PIWIS 3 unit - for likely less $$$ - and PIWIS can do it all - literally!
Good luck!
