Panamera 971-2019 TMPS ISsues as in the PCM, the tire meny is greyed out and wonder if the module is croken, tireshot couldnt get a reading from the tiresensors, but 4 cantjust stop at the same time..
Do you know where the TPMS module is located? I see some say rear right in the trunk. Any drawing? or just need to remove all trunk carpets and flooring?
You are right in that it's unlikely all four sensors crapped out at the same time. Before you go taking apart your interior, either scan for faults with a PIWIS or other bidirectional tool, or try resetting it with a TPMS tool. Discount tire will (try to) relearn your sensors for free.
so the tiretool-sensor device didnt get any reading at all from them,,so battery dead most likely. Anyone know the SKU for TPMS for panamera? seems like i need the org nr to find OEMs.
This says its fits my 2018, but there are different frequencies listed. I would give your vin to them or another dealer to verify. I still find it hard to believe that all four sensors had the battery die. Have you checked for any faults?
HI, well the fault says NO comm with head unit, and the meter couldnt trace any frequency transmitting from any of them..so we are trying to mount my other weels and see the outcome..
Thnx
There is an antenna in each wheel well and a control box for the system somewhere else. I would do a little more digging before you throw parts at it, but let us know the outcome.
HI the anrtenna module is located under the car next to the right rear wheel, i have a pana gts 971-2019
I think I am having the same issue. I cannot get a reading from any of the 4 sensors and I replaced 2 when I had my tires changed and they could not connect to them. When it started to fail, I would get blank and then intermittant readings for a few weeks and then it just failed.
Does this sound like your issue.
To get to the module / antenna, do you access it from the trunk or from the wheel well? If wheel well, can you offer some guidance? Do I need to remove the wheel or can I pry open the wheel liner and find it?
