Panamera 2010-Current
Used Quick Jack for the 1st time.
Old Sep 30, 2024 | 03:47 PM
djdonte's Avatar
djdonte
Originally Posted by leeadrian3841
Is Powerstop good with stopping, dust, and noise?
I never tracked my cars but yes, no noise, low dust and stopped as good as OEM for me.
Old Sep 30, 2024 | 08:35 PM
leeadrian3841's Avatar
leeadrian3841
Thanks. I drove today to work and back. So far, no squealing. I will let you know if the squeal comes back.
Old Oct 1, 2024 | 11:40 AM
B Russ's Avatar
B Russ
So I have a 971 and a 991, which one would I get?
Old Oct 1, 2024 | 07:01 PM
leeadrian3841
If you are only using Quickjack for Porsche, especially the Panamera, I would get the extended version. 5000 or 7000TLX. I have cars with shorter lifting pad distances, so I had to get 5000TL with frame extension for my Panamera. Measure your lifting pad distance and choose what you need.
Old Oct 2, 2024 | 07:31 AM
Tcaschy021's Avatar
Tcaschy021
I was looking at this as well. Seems like it should work.
VEVOR Car Lift, 25.6" Max. Height, 5,000 LBS Capacity Portable Car Lift, with Extended-Length Plates, Heavy-duty Carbon Steel Truck Lift with 120V Power Unit, Auto Car Jack Lifts for Home Garage Shop | VEVOR US
Old Oct 2, 2024 | 08:25 AM
leeadrian3841
I actually have a friend who purchased the Vevor 7,000lbs lift. Saw the construction and material of the units. In comparison, QJ seems used better materials and far better welding joints. Also, Bendpak is well known for auto lifts as to Vevor makes wide spectrum of items.
Old Mar 7, 2025 | 08:37 PM
mhariush's Avatar
mhariush
I was just looking at the Vevor, did your friend get the Vevor that lifts in an arc like the QuickJack or the one that lifts straight up? That Vevor that lifts straight up looks enticing...
What's his verdict after these months, do you know?
