Panamera 2010-Current
Personal setting
Old Jun 29, 2024 | 05:05 PM
Tommyhchoi's Avatar
Tommyhchoi
5th Gear
Default Personal setting
I had no problem with saving seat positions and other personal setting by pressing set, then save. Done.
key fob #2 my wife's key, however, doesn't save any settings repeating the same process. No beeping. Doesn't save. I tried pressing set, then the number button. It beeps. But nothing is saved...
I've tried some internet searching and some say unclick the auto-save. It doesnt have that function.
Any help?
Old Jun 30, 2024 | 07:11 AM
chaos2984's Avatar
chaos2984
What year car do you have. Mine has a key button to save the settings to the key.
Old Jun 30, 2024 | 11:28 AM
Bart Poladsky's Avatar
Bart Poladsky
Same here. 2013 Turbo. Can not get 2nd key to sync with settings. My particular annoyance is the side mirror not pointing to the curb when I reverse.
When I hit set and then the key icon , no beep with the 2nd key.
Old Jun 30, 2024 | 01:35 PM
Tommyhchoi's Avatar
Tommyhchoi
5th Gear
2018
Old Jun 30, 2024 | 04:21 PM
chaos2984's Avatar
chaos2984
Originally Posted by Tommyhchoi
2018
When your trying to program it to the key, are you pressing the memory button then the key switch? That will put the settings into the key.
Old Jun 30, 2024 | 05:02 PM
Tommyhchoi's Avatar
Tommyhchoi
5th Gear
there's set button
1
2
when I save my setting with my key, I press set button, then key button. It beeps.
Wife's key, I do the same, set button, then key button. It doesn't beep, and it doesn't save.
when I press set, then #2, then it beeps. But still doesn't save.
Old Jun 30, 2024 | 09:26 PM
chaos2984's Avatar
chaos2984
there's set button
1
2
Humm interesting. I wonder if there is an issue with the key. Have you tried to remove the battery cables and put them back on after a min to two? Sometimes that helps. Hard to say without looking at a scan tool data.
Old Jul 3, 2024 | 03:45 PM
H2Owon's Avatar
H2Owon
When programming the key, make sure the other key is out of range.
