Panamera 2010-Current
Chassis system failure - HELP
Old Feb 5, 2023 | 02:13 PM
njmporsche's Avatar
njmporsche
Default Chassis system failure - HELP
extremely cold this weekend and got the chassis system failure on my 13 GTS panamera.
just went back in the car again because the weather is warmer, but after a few minutes the message came back.
can someone please help? And anyone in NYC area to help me out here?
Chassis System Failure
Old Feb 5, 2023 | 02:16 PM
amphicar770's Avatar
amphicar770
Looks like air shock/bag failure. Could be pump. There is a whole sticky thread on air suspension issues. It's not a matter of IF they will fail, it is a matter of WHEN.
Most likely costly $$$ unless under warranty.
Old Feb 6, 2023 | 12:01 PM
sac02's Avatar
sac02
Probably the #1 question asked on the Panamera forum?
Panamera Air Suspension System Info - Rennlist - Porsche Discussion Forums
Old Feb 6, 2023 | 01:02 PM
skiracer's Avatar
skiracer
Before panic sets in and you take it to a dealer, try this:
1. Get the car in a heated area and let it warm up (cold temps cause O-rings to shrink and leak, let them warm back up and expand)
2. Put your battery on a strong charger and let it charge up fully overnight (sensors are extremely sensitive to low-voltage conditions).
3. Check the next day - start the car and see if air suspension will lift the vehicle.
Good luck!
