Taycan mission wheels on Panamera
Hi all. I love the Mission E wheels that come on the Taycan. Can I put them on a 2022 Panamera, and if not, is there an aftermarket version that will fit?
Searching the internet I found this info. Looks like the offsets are different. Rears might fit as they are close, but fronts could be a problem. You can use spacers to reduce the ET number but going in the other direction doesn't work. Fronts on the Taycan are 11mm more inwards than the Panamera. Rears on the Taycan are 3mm more inwards. I mean it could work (with the emphasis on could), depending on where the centerline of the uprights are relative to the fender and suspension components.
Taycan Mission E Wheels
Front 21x9.5" ET60
Rear 21x11.5" ET66
Bolt pattern 5x130
Centerbore 71.65mm
Panamera 971 Wheels (Exclusive Design, various styles 21")
Front 21x9.5" ET71
Rear 21x11.5: ET69
Bolt pattern 5x130
Centerbore 71.6mm
Front 21x9.5" ET60
Rear 21x11.5" ET66
Bolt pattern 5x130
Centerbore 71.65mm
Front 21x9.5" ET71
Rear 21x11.5: ET69
Bolt pattern 5x130
Centerbore 71.6mm
