Wheel sizes for 970?
Hi,
Will the 20" Panamera Design Wheels stock for 2016+ models (971) fit in my 2011 panamera (970)?
20" Panamera Design Wheels specs:
Front: 9.5 x 20 ET71 wheels with 275/40 R20 tires
Rear: 11.5 x 20 ET68 wheels with 315/35 R20 tires
970 stock wheels
295/35r20 for rear, 255/40r20 fronts
Thanks!
970 stock wheels
Thanks!
@tonyhw206 The wheels vary between the variants of the 970 so you need to specify the year and model. However, I believe all of the 970 used a different wheel offset than the 971. For example, the 4S specifies 9.5 x 20 ET65 Front and 11.5 x 20 ET63 Rear for Summer performance tires. If you plan to use chains, the winter wheel offsets are slightly different to allow chain clearance. Your owners manual should give you the various wheel specification options for your car. If you don't have the manual you should be able to download a PDF manual from the My Porsche website.
I have attached links to a website where you can see the standard sizes of the tires/rims from both the 971 and 970 models. It is also broken down into years. Please find your model and just compare it to the size of rims that came standard on your 970 version. I hope this helps you sort out the answer.
2020 Panamera Wheel
2011 Panamera Wheel
2020 Panamera Wheel
2011 Panamera Wheel
