I searched and found minimal info on this unit. Anyone running the lowering module on a 971 sport turismo with pictures? Any reviews of reliability or how the lower setting effects ride quality?
Enthusiast version of a Durametric works perfectly. Did it on my Cayenne as well. Just go into suspension settings and lower the ranges 1/2 inch, so every setting is lower by 1/2 inch. Instructions should be out there on how to do it, takes about 15 mins to do and no modules or wiring needed.
Were you able to successfully adjust this with a Panamera? 970 or 971? I don't believe I've seen anyone that has successfully adjusted the suspension height on the Panameras with Durametric. Their site also mentioned that Durametric does not have any adaptation features for air suspension on Panameras, other than reading faults, and clearing faults. Please let us know, that would be great if it does work.
