Brushed aluminum interior build
Does anyone know if the brushed aluminum interior reflects sunlight like the normal aluminum interior? I want to prevent sun glare in the Panamera by eliminating any glossy aluminum bits and was wondering if anyone has driven in a car with a brushed aluminum interior before.
Here's a code for the build I made, which I found to be quite nice: PLA77DX5
The brushing is very deep and helps diffuse sunlight, but that also means there are more angles where it does reflect significantly. If you already know you are sensitive to it I would get the leather trim in marsala.
Disclaimer: didn't drive the trim, but looked extensively at the trim options in the Atlanta center.
