Lowering module location/installation
Hey. Just got a cargraphic lowering module.
and it did not come with installation instruction. Anybody can share who has installed it?
i know it is somewhere in the trunk, do i need to just pull out the liner? Or is there any screw that i need to remove first? I can't wait to install but i don't want to mess it up
thank you in advance
And if you want to adjust, follow these instructions.
Couldn't find it anywhere, had to contact them, it's not in their instructions oddly.
https://rennlist.com/forums/panamera...l#post15608797
I have a question I am interested in this module for my 2018 4S also. I saw somewhere that it has an on and off switch that you have to mount somewhere. Where are people mounting that switch, also what are you doing if car has to go in for warranty work are you taking out the complete module.
Hey,
you can just disconnect it for service, there is on and off switch but the wire is not very long, so I just left it on and left it inside the liner.
it only work on lowered position, so I don't think lowering switch is really necessary
When you want to turn it off, just flick the switch and you're back to oem specs.
Thanks for the replies, I have one more question my wife drives the car sometimes and I don’t want her driving it in the lowest position. I have the sport package does it still give different heights in sport and sport plus.
no, only lowers when you manually lower the vehicle
