Huge 2010-2016 Panamera Recall
has anyone set up an appt yet to get theirs done? did anything rattle or break after the recall was fixed?
i'm about to list my turbo and have a feeling this might come up on recall searches. might have to do it to sell without issue.
Here's another recall for rollaway Panameras. 2010 - 2016. The fun doesn't seem to stop.
Edit: My 2014 P4 didn't paint up on either NHSTA nor Porsche recall sites. Not sure if it's too early or what.
I just booked mine in, but may delay... I was told they need to get into the blower unit and access is via removing the glove box. My understanding is that they are doing a temporary fix now and IF they deem it necessary the car has to go back later in the year to have the part replaced. I pushed to wait until the part was available so I didn't have to go twice (more that I don't want the interior taken apart twice!) but the service advisor was very instant that we do this asap! I plan on calling back in a few days and cancelling until the part arrives.. I just have that feeling...
I was booking an oil change and both recalls came up. I'm going to have them addressed then (mid-July).
My read is that there's an initial fix, and then a permanent fix will come.
you got everybody scrambling to find their VINs
ODD, when I enter my VIN I get this "We could not find campaign information about this vehicle because the number you entered contains an error or is not in our system."
if I copy and past the VIN into a VIN lookup site it finds my cars info no problem
Thanks for the original post!
Porsche received its first Panamera complaint in 2013 and thought it was an isolated incident. Then in 2015 another report was received but the automaker couldn't find a reason for either incident.
Over the next three years four more incidents occurred but investigators still had no clue what was causing the problems. Porsche also says most of the incidents ended in smoldering that was self-extinguished.
In January and April 2019, Porsche was informed of two additional incidents similar to the previous reports, except this time engineers were able to determine what caused the problems.
So that is a total of 8 out of over 30,000 vehicles. Seems to be a very isolated problem.
Dealer also suggested bringing it in for the temporary fix which I declined. They confirmed that the replacement parts are coming in by July 16th so I had them schedule my appointment for the 16th.
I thought the replacement unit was not going to come out of production for a couple of months still. I guess that's good news.
I was told no date yet but late this year.. I'll call again and see if they can give me a better ETA.
This is the information from my service advisor, following research on the recall...
Sounds like one blower motor part number is more serious than the other? Inconsistent information on replacement part availability?
My Panamera has two unrelated problems that needs to be addressed separately and sooner than later... freon leak and driver's side air temperature mixing servo (flap) failure.
"I did some research and unfortunately we’re not expected to receive parts until Sept. I looked into both recalls (there are 2 repairs); Porsche has the main recall AkA7 for blower motor, if the part number applies then we have to perform the 2nd recall WKE0 which is the interim remedy until parts become available for motor. We won’t know if the interim remedy needs to be performed until we check the part numbers. The repair will not consist of recharging or leak testing; it’s strictly a mechanical component repair."
Site indicated neither of the 2 Recalls applied to my VIN. Called PCNA office earlier who advised me NO recall applied to my VIN.
Hmmmmm.... Houston, I think we have a communication problem here!
