Who has the highest mileage on a Panamera?
#136
I wonder if it's predictable. Many here report reliability. We don't. Ours, now at 60k is in for another laughably expensive bit of maintenance. Our water pump is making a noise so replacement is on the table necessitating thermostat replacement in a 'while we're in there' operation.
We're looking at U$4,000 for the parts and labor. We have a plain jane /4.
FCP Euro has a water pump replacement kit for $308 for a 6 cylinder S model https://www.fcpeuro.com/products/por...e-9481060330kt
Any local shop (forget about a specialist, look for a reputable neighborhood shop) can replace a damn water pump. $4k for parts and labor even if you add a t-stat and some other bits and bobs is ridiculous.
#137
A PPI from a reputable independent shop will save you thousands in surprises. Also, that same independent shop will save you thousands down the road compared to the dealer. I've seen dealer techs that really take pride in their work and dealer techs that would make Jiffy Lube techs look like geniuses.
Are you going to a Porsche dealer for this?
We're going to a local Indie. Living far out in the rural, we are limited to garages that will work on anything exotic. Something is funny in your post because, AFAIK, the /S is 8 cylinder. Our /4 is a 6. Well, no matter, we're stuck with this and saying other places mean less expensive repairs is interesting but we have no access to such shops.
#139
Not quite sure if I fall in the "Alot" of money class but my 2012 Pana S has 83K miles on it. If its more than 8 hours drive I most likely will not take it but take one of my company cars to keep the miles off it. I also have several cars between my 818 spyder, my speedster, a 968, a Jeep Wrangler and my 997TT. It is a 2010 and only has 13K mikes on it. Contrastly my Harley ultra classic has over 100K miles in it so go figure. I simply spread the miles around but it's not because I don't love driving the Pana S. Dare I say I have had zero issues with it and temp fate.... too late.
Cheers, Mike
Cheers, Mike
Deezflip (01-24-2022)
#140
My 2011 Turbo has 102k miles. I bought it 1K miles ago. To my knowledge, major issues have been the normal things you read about on this forum plus a couple of others.
--High pressure fuel pump
--Leaky cooling system at the weak point under the manifold
--Front diff and both front axles just replaced (diff was shot; guessing it was lack of maintenance)
--Rear transmission mounts (likely related to above)
--Passenger-side rear door actuator
--Front parking sensor failure I'm currently living with
--Leaky front air strut I'm currently living with until Spring service
--EVAP system
--Ignition-related maintenance
--Lower control arms
I plan to drive it until the wheels fall off.
--EVAP system
I've got 120xxx on mine and have done most of those same services. HPFP, Evap, (Haven't done my driver's side rear door lock actuator, but it's not working) , Cooling system, coil, and a couple other misc bits.
#141
Are the lock actuators a common failure point? He could use some guidance if you know what to look for (and me too if they fail commonly).
chassis (01-02-2023)
#145
#146
--EVAP system
--EVAP system
Jan-Åke_Klement (05-31-2024)
#149
Agree. They specify water based lubricant for cooling system O-rings but this application did not use that based on my observation. They should have noted that exception. If I were rushing I would have missed this. The dealer techs are probably aware.
#150
I the reason you don't see many Panameras with super high mileage is two fold.
1. Many owners likely have multiple vehicles. When the weather is bad. I use my SUV.
2. The Porsche tax. On many old cars parts are cheap and you do not need things like dealer coding. On a Panamer with 100k+ miles, bad air shocks or a hybrid battery failure could exceed the cars value.
