Lift settings in PCM on non lift suspension
in the car setting I keep getting the suspension height/lift icons. It even goes to sub menu. Nothing of course happens. Is this common, or is the PCM about to have a nervous breakdown...
Is the car changing height? Are you hearing the air pumps working but the car is not changing heights? The air ride system has some know quirky things with it. Sometimes the shocks and compressors go back, but the fixes aren't terrible if you can do the work yourself.
Sorry, just saw this reply. I left out a small critical detail. The car does not air suspension, but does have a functioning air suspension menu tree.
