Panamera 2010-Current
PDK issues/noises/function question
Old Nov 23, 2018 | 09:44 AM
martinced's Avatar
martinced
Originally Posted by ciaka
I think all PDK, in normal mode, start from 2nd gear.
When you set to sport, that is when start begins from 1st.
970 Panamera 4 from 2013 here. PDK always starts in 2nd gear, even in Sport mode as far as I can tell. It's when in Sport Plus that it starts in 1st I think (don't know for sure because I don't even have Sport plus). Only time it'll go to 1st gear is if I'm on a steep ramp or if I put the PDK in manual mode.
And that said this PDK on my 970 is buttery smooth: not harsh at all.
Old Nov 23, 2018 | 11:08 AM
small car lover's Avatar
small car lover
If my '14 970.2 TTS is on a steep enough incline, seems to be about a 12% grade or steeper, it will start in 1st gear regardless of mode. Otherwise 2nd gear in comfort and sport mode, 1st in sport+.
Old Nov 30, 2018 | 07:53 PM
SaratogaLefty's Avatar
SaratogaLefty
So I just had the PDK software update done and now the "lurch" is completely gone. Car is very smooth on stops and starts.
Old Dec 1, 2018 | 04:52 PM
B Russ's Avatar
B Russ
I have found the only time it starts in 1st is when I have the shifter in manual. It will as described above go down into 1st in auto if starting off on a steep hill
Old Dec 1, 2018 | 06:45 PM
SaratogaLefty
My 2018 E-Hybrid always starts in first gear but very quickly upshifts. I am talking in both E mode and ICE mode.
Old Dec 4, 2018 | 01:43 AM
Sliu6122's Avatar
Sliu6122
Does anyone know how to check if my PDK is up to date?
Old Dec 4, 2018 | 02:14 AM
SaratogaLefty
Porsche has issued a "campaign" software update for the 2018 Panamera. The next time you take it in they will automatically perform the update. It will then show up on your paperwork indicating the update has been done.
Old Dec 4, 2018 | 02:18 AM
Sliu6122's Avatar
Sliu6122
i just bought the car and don’t want to wait 9500 more miles before fixing this issue. I guess I’ll give them a call tmw
Old May 14, 2020 | 12:53 AM
jrodporsche's Avatar
jrodporsche
Default pdk noise
I have a 2014 991 turbo. I have a small rattle should inside the cabin at idle. At first we thought the rattle noise may be coming from the rear pully tentioner, but you can only hear the rattle inside the cabin. You can not hear any unusual noise while standing outside at the rear of the car. It is hard to describe the noise , it come and goes and its not very loud, but you can hear it if you try to notice. it is like a rotating metal sound or disk metal rubbing, swooshing sound. Goes in and out.. I think when car is cold it sounds more.
One porsche mechanic said it is the PDK clutch plates.. under low load.. at idle there is a little vidration noise chatter of plates? as soon as you apply load ( rev up a little ) the sound goes away. I replaced the PDK oil and the idle sound is still there.
Has anyone had this experience?
Old Aug 16, 2025 | 10:58 AM
Adrianadernew's Avatar
Adrianadernew
did you solve the problem?
in my opinion this sound is from the PDK transmission / pdk clutch
I have the same whoooo (but only when hard accelerating )- while changing from gear 2 to 3 and 4 to 5 gear
Movie - video on youtube
Old Aug 16, 2025 | 11:46 PM
djdonte's Avatar
djdonte
If you're talking about the "whooooo" noise right after a shift, there are a few other threads about that around here. I have it too just not all the time. It's almost like a whistle. It definitely sounds like air rushing, a blow off valve or similar. It doesnt sound mechanical in my car at all. Of course the dealer could not replicate it.
Old Aug 17, 2025 | 08:00 AM
Adrianadernew
I've seen and read many threads about this sound, but I haven't found a solution. In my opinion, it's definitely a problem with the gearbox – specifically, the PDK clutch.
It only happens in the second clutch from the even gears (k2 clutch). If the sound also occurred in the odd gears, you might be right that it's related to the air. The air diverter valves operate regardless of whether the gear is in an even gear (2-4-6-8) or an odd gear (1-3-5-7).
Old Aug 18, 2025 | 01:07 PM
PSEE's Avatar
PSEE
QUESTION: You state that it only occurs in the even gears - shifting into the even gears or from them?
Old Aug 18, 2025 | 02:42 PM
Adrianadernew
as I wrote four posts above - only when shifting at 60-100% accelerating power from even gears upshift into odd gears ( from 2 gear upshift to 3, from 4 upshift to 5 )
Old Aug 18, 2025 | 04:56 PM
djdonte's Avatar
djdonte
Mine only makes the noise on a 2-3 shift. IMO if it was the PDK I think the dealer would be more help.
