Panamera 2010-Current
stereo controls
Old Oct 2, 2018 | 05:31 PM
billgrande's Avatar
billgrande
2nd Gear
Default stereo controls
Can I set up my stereo to the default mode I want? I want it to be on Bluetooth when I start it up so it will instantly start playing the music on my iPhone.
Old Oct 2, 2018 | 05:35 PM
amelen's Avatar
amelen
It typically defaults to whatever mode you had it in last.
Old Oct 2, 2018 | 06:28 PM
DevLep's Avatar
DevLep
Perhaps in the 971? In my 2016 if I turn it off while using bluetooth it defaults to FM when I restart the car. Quite annoying
Old Oct 2, 2018 | 06:31 PM
amelen's Avatar
amelen
Ahh, yes, I have a 971.
Old Oct 4, 2018 | 05:37 PM
billgrande's Avatar
billgrande
2nd Gear
This is a 2012 Panamera and it's defaulting to stereo radio. VERY LOUD stereo radio. Much louder than the music I had been listening to. It's so annoying. And the manual is so daunting. That's why I reached out here.
Old Oct 5, 2018 | 09:52 AM
HP41's Avatar
HP41
Sounds like you have the "Comfort Memory package". It will default back to whatever is stored as the preference for the key used to start the car. To change / overwrite the stored values.
1. Set the radio where you want it to be
2. Press the "Set" key and then the "3" key on the drivers door.
3. You should hear a beep if it accepted the programming.
See if this helps.
Chuck
2014 Panamera 4S
