Panamera 2010-Current
Rear wiper failure
Old Aug 16, 2018 | 03:53 PM
NJS_04_996's Avatar
NJS_04_996
Angry Rear wiper failure
Has any one had difficulty with their rear wiper? Mine apparently just failed this morning- only goes about half way and stops in the middle.(Its an '12).
I guess I'll check over in the Cayenne forums as well.
Old Aug 17, 2018 | 06:51 AM
K777's Avatar
K777
Does it return to rest position ?
If not maybe just the arm has come lose on the splined spindle and needs the nut locking up?
Assuming its that type of fitment.
Old Aug 17, 2018 | 08:43 AM
NJS_04_996's Avatar
NJS_04_996
No, it stops in the twelve o'clock position. If I turn it on, it will swing to the left (9 o'clock) in a fairly smooth manner, but then jerkily move back to about 11:30 without ever go past that to the right. Can't really move it much by hand (although not forcing it) I'll probably take a look at it from the inside of the hatch on Sunday. Read a post in the Cayenne forum where spraying some WD40 near the motor fixed their problem (at least temporarily)
Old Aug 17, 2018 | 09:26 AM
K777's Avatar
K777
but you've flipped the cover up to check the arm is still located tightly on the splined shaft ?
Old Aug 17, 2018 | 09:45 AM
NJS_04_996's Avatar
NJS_04_996
If you are talking about the little plastic cover on the base of the wiper arm, yes I just checked that and both the nut and shaft rotate with the arm, with only about 10 - 15 degrees of play. (again, without forcing it further)
Old Aug 17, 2018 | 11:44 AM
K777's Avatar
K777
OK, if the WD40 trick doesn't work I would imagine theres some gearing inside the motor assembly that's probably worn, maybe the gears are plastic and worn if its been jammed in the past.
Hopefully just something tight/seizing that the WD40 will free off.
Old Aug 17, 2018 | 11:50 AM
K777's Avatar
K777
just found this, https://rennlist.com/forums/928-foru...-overhaul.html
its a 928, but basically the technology will be the same.
and this https://rennlist.com/forums/cayenne-...t-working.html
Poss you seen both. Would be amazed if yours has "rotted" like the second link.
I think if a previous owner has been clearing snow/ice it can potentially wear the plastic gears out. if its intermittent, maybe only a few teeth have rounded?
