970 Panamera add CarPlay
2014 Panamera PCM3.1 add CarPlay box,need open PCM headunit add touch screen signals inject circuit board,wireharness is Pin to Pin connect.
CarPlay box audio output connect to PCM AUX input by wireharness,original AUX port in central hand box need connect a 3.5mm empty jack to keep AUX volume offset same with other audio source.
Control with new steering wheel
Price?
How difficult an install is it?
Mike
Mike
I like that new steering wheel! If I were a bit more tech savvy I'd try and install it on mine..
1,Remove PCM3.1 head unit,
2,Open PCM3.1 head unit cover,install touch screen signals inject circuit board inside,
3,Connect CarPlay box wire harness to PCM,Pin to Pin connect,
4,Find space to fixed CarPlay Box,I installed closed burmester amplifier,covered by front passangers floor.
5,Connect Microphone of carbox,I fixed it on the top of steering column cover.
