Panamera 2010-Current
Clock Survey
Old Apr 4, 2018 | 11:16 AM
ajriches01's Avatar
ajriches01
Default Clock Survey
All - some help please.
Panamera has been in with the usual issues - SatNav jumping around (PCM update), flaps not opening properly (adjustment to petrol and electric replaced), battery (Porsche accepts it's rubbish in the winter) and the clock.
The clock for the last 30 seconds is out of alignment and it looks cheap as hell. Porsche response is simply they are all the same. See pic by way of illustration. Please take a look at your clock and tell me if it looks the same (i.e. they are all out of alignment)? Shame it doesn't use the 911 clock - a thing of beauty!
Thanks in advance all
Old Apr 4, 2018 | 06:21 PM
cerbomark's Avatar
cerbomark
I don t see an alignment issue in the pic but I can say that it not nearly as nice looking as the clock in my 2015 Pana.
Old Apr 5, 2018 | 04:50 AM
ajriches01's Avatar
ajriches01
Argh that's not helpful!! So you think it is pointing at 46? I think not!
Come on people - more input please.
Old Apr 5, 2018 | 08:48 AM
cerbomark's Avatar
cerbomark
o if you mean the hand direction it s pointing to 45 1/2.
I do agree that it s cheap looking at best.
Old Apr 5, 2018 | 10:08 AM
ajriches01's Avatar
ajriches01
Thank you!
So the question is - do any 2017+ Panameras do the same?
Old Apr 5, 2018 | 11:23 AM
K777's Avatar
K777
Mines exact. But I now realise it needs a duster in there !
Old Apr 5, 2018 | 12:55 PM
ajriches01's Avatar
ajriches01
Good man! Keep the pics coming please! Gives me good ammunition to go back and demand they change it.
Old Apr 5, 2018 | 01:03 PM
ajriches01's Avatar
ajriches01
PS. love the dedication of capturing the same second!
Old Apr 5, 2018 | 03:05 PM
SaratogaLefty's Avatar
SaratogaLefty
Hey, what happened to your 0-60 experiment with your app? What is the name of the app and how does it work?
Old Apr 6, 2018 | 04:25 AM
ajriches01's Avatar
ajriches01
Simply called "Acceleration Timer" in the Android Store - uses GPS. Not had a weekend at home until this - will make a mental note.
Come on team - more clocks please!
Old Apr 6, 2018 | 06:01 AM
K777's Avatar
K777
Your welcome, thought it would help you to show your dealer.
Today my Biz partner is in so I will try check his later.
Old Apr 14, 2018 | 02:01 PM
cometguy's Avatar
cometguy
Hearing your problems makes me nervous with the impending arrival of my Panamera 4 ST E-Hybrid in June.
Please tell me more about the battery issue; just low mileage range in cold weather?
Are others having problems with the fuel/electric port doors? I presume you mean they don't open easily? Do they close ok?
As for the clock: I dislike having only an analog seconds hand. I wish it was a normal analog clock, with a digital compass; or an analog compass with a digital clock. But as it is, I think it's stupid. Who wants to just watch a second hand move around on an analog dial, really? What a waste of space.
Old Apr 17, 2018 | 04:24 AM
ajriches01's Avatar
ajriches01
Some minor teething issues but perhaps just with 2017.
Battery: Sucks in the cold, but noticeably improving now it's warming up (lasting 2 commute days instead of 1).
Fuel Port: Adjusted, now fine
Electric Port: replaced, now fine
SatNav: Still an issue, hopefully they fix on the next booking!
Clock: After K777's help, they are going to replace - thanks! You can stop the clock if you wish by setting the chrono but it really isn't noticeable most of the time. It's just not a precision item like the 911 clock is.
Don't be nervous, overall it is a phenomenal car!
Old Apr 17, 2018 | 06:07 AM
K777's Avatar
K777
AJ what's your satnav issue (this threads to long to scroll back through) - I've been waiting an antenna since January, apparently its just arrived into stock in Germany. Good about the clock.
Cometguy, as AJ says, it is truly a phenomenal car. So many good points. And most of the issues are perhaps a little "pernickety" to quote an old acquaintance, ask any car model owner and they will have an issue with something.
Old Apr 17, 2018 | 06:10 AM
ajriches01's Avatar
ajriches01
It shows me as being about 20 metres to the side (Sometimes more, sometimes less). Same as you? If so, I will push the dealer to see if it is now in stock and pre-order. I had mentioned before that I thought this was the issue from others mentioning on the forum and his reply was that there are none in the UK so doesn't see how it could be (quite an aggressive response really!).
