How to tighten up this interior piece...?
Hi -- I've found that both driver and passenger door arm rest continuations are loose (the little "bump" in low/mid of picture) --- anyone help me with how to snug them up...?
Other than a trip to the dealer....
Thanks...
Kevin
Thanks...
Kevin
3rd Gear
I had the same problem. There’s a plastic/rubber piece in the front of that continuation that can be removed by prying with your fingernail or something similar. There’s a bolt underneath that can be tightened so that the continuation no longer moves.
Take the entire piece off because there is a plastic part that can click in place locating the part closer to the pillar. Then place the screw and tighten. Mine was always sticking out further than necessary.
I had the same problem with the loose armrest extension. Took to dealer because car was still under warranty. Told that it’s a very common issue and poor design. Something on the inside (maybe plastic tabs??) breaks and then it keeps giggling. Mine was replaced under warranty but I had to wait a number of months as part had to come from Germany! Was told by the dealer that Porsche spent a ton on replacing these under warranty on the 970’s. I think it’s been redesigned in the 971’s.
If your car is still under factory warranty I encourage all to check and take to dealer before out of warranty! It wasn’t a cheap replacement part!
