Wheel Spacers - 2015 Panamera S with 20" Turbo Design Wheels?? What size ?
I am having a hard time finding information on what size wheel spacers to get. ON the internet, There is info on the Turbo II wheels, but not the Turbo Design wheels I have
Size is
9.5 x 20" - 65 mm offset front
11 x 20" - 68 mm offset rear
What size spacers are recomended? Is there a brand people like? Does anyone make black ones since my hubs are painted black?
Why does Porsche say to go no more than 5MM? What happens if you go beyond that?
Even at 15mm, which is just over 1/2 inch, its hard for me to see a big difference in how the car will look?
If I stay within the Porsche 5mm recommendation, its hard to imagine any difference.
Size is
About 45-48mm ish are flush with the Panny.
The 5mm spacers wont do much and wont have a hubcentric lip, I believe its at least 7mm or larger for it to have a lip, you need this to prevent any vibration on higher speeds. I am running 20mm in my rear and about to place 15mm in the front (my tires are too large and rubs with the 20mm in the front).
Good luck!
Good luck!
I have the 19 inch sport wheels and went 7mm front and 15mm rears. Came with longer bolts too. They look better than before with no ride difference or vibration. They are further out than even those 20 inch stock wheels.
https://www.6speedonline.com/forums/...er-vendor.html
and I imagine yours may sit slightly wider with the 20 s. Not sure of the offset difference between the 19 s and 20s. If you call that vendor they will talk you thru it and if you want to change size when you get them you only pay shipping to replace.
