Fully Built Cayman S 3.8
For Sale2006 Porsche Cayman
Price
$45,000• Trade
- Location Los Angeles, CA, 90049, USA
- Condition Used
- VIN WP0AB29836U780726
- Mileage 96,000
- Engine 6 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Coupe
- Exterior Color Gray
This is a fully built back road and track monster that can also be driven daily. Has pretty much every single top shelf modification available, and all work has been documented and done by the best shops - Vision Motorsports, Johnson's Alignment, Wheel Enhancement, Sublime, etc. Mileage is chassis, about 30k on motor. Fully serviced and ready to beat on GT3's for a fraction of the price.
Carfax is clean but shows a mileage inconsistency because the 3.8 was originally from another car the previous owner had and crashed. Total chassis miles are about 96k, engine miles are about 59k, but engine was totally rebuilt at 38k, so there are about 21k miles on the rebuilt motor. Tons of work done on this car and it's in turnkey state.
MODIFICATIONS
- 987.1 Cayman S Engine 3.8L Build
- JE Forged Pistons
- Carillo Rods
- Vision Chrome Alloy Steel Sleeves
- Knife-edge Crank
- 997S Oil Cooler
- Bilt Racing 2.5 Quart Oil Pan
- Swirl Pots
- Cylinder Head Ported / Polished
- GT3 Throttle Body
- GT3 Plenum
- Porsche Motorsports AOS
- Underdrive Pulley
- Power Steering Delete Pulley
- Porsche Motorsports Electric Power Steering
- Bilt Racing Rack Adapters
- LN Low Temperature Thermostat
- Additional Center Radiator
- Milltek Full Exhaust
- Sachs Clutch
- AASCO Lightweight Flywheel
- Wavetrac Limited-slip Differential
- Schnell Shifter
- Numeric Shift Cables
- Bilstein B16 DampTronic Coilovers
- Tarret monoballs
- Tarrett Upper Camber Plates
- Tarrett Drop Links
- GT3 Sway Bar
- GT3 Lower Control Arms
- Body Mount Tie-downs (Front / Rear)
- GT3 Master Cylinder
- Girodisc Rotors
- Pagid Yellow Pads
- Roll Cage / Harness Bar
- Schroth Harnesses
- Orcal Matte Metallic Dark Silver Wrap
- Painted Center Console
- GT3 Alcantara Steering Wheel
- GT3 Alcantara Shifter
- GT3 Alcantara Emergency Brake Handle
- Carbon Fiber Ducktail Spoiler
- Rennline Smile Vent
- Rennline Bumper Mesh Grilles
- Rennline Track Mats
- Rennline Tow Hook
- Rennline Phone Mount
- Rennkit Bluetooth Adapter
- 19" HRE Forged P43 Wheels
RECENT MAINTENANCE
- Clutch / Flywheel
- Battery
- Starter Motor
- Axles
- Gas Struts (Hood / Trunk)
- New Tires
Under the wrap, the car is seal grey - the side mirrors are not wrapped, if that gives you any indication of how close the colors actually are.
HVAC is intact and works well (heat and AC).
Car was built by Vision Motorsports, and I have the spec sheet from the prior owner, which was confirmed by Vision.
The engine has about 21k since being rebuilt and is very strong overall. I haven't tracked it, I drive it on canyon roads and as a daily about 50% of the time.
Overall the car is very mechanically sorted. Cosmetically, the car presents well, but some interior plastic pieces show some wear and the wrap is fine but not perfect - a track person would recognize this as a track car. Non-car people will think it looks like a stock Porsche. PCA toothpick-wielding weekend detail warriors need not apply.
Does that help answer all the questions?
