Macan 2014-Current
Sponsored by: HBI Auto
A couple of issues
Old Oct 30, 2016 | 07:29 PM
bcgreen's Avatar
bcgreen
Default A couple of issues
Is there a fix for the radio - I have to check the box for surround FM each time I start the vehicle.
Every time I start the vehicle I have to turn off the ac.
Old Oct 31, 2016 | 04:00 AM
Need4S's Avatar
Need4S
After you set your sound preferences, save the settings to your key and to your seat setting (1 or 2). Maybe it keeps reverting because you previously set it differently and saved it.
Old Oct 31, 2016 | 11:37 AM
Philip Goughary's Avatar
Philip Goughary
What model year?
Old Oct 31, 2016 | 12:28 PM
bcgreen's Avatar
bcgreen
Originally Posted by Philip Goughary
What model year?
It's a 2016.
Old Oct 31, 2016 | 12:31 PM
bcgreen's Avatar
bcgreen
Originally Posted by Need4S
After you set your sound preferences, save the settings to your key and to your seat setting (1 or 2). Maybe it keeps everting because you previously set it differently and saved it.
Not sure how do you save it to my key?
Old Oct 31, 2016 | 08:28 PM
Todd B's Avatar
Todd B
The key button on the door if you have the memory package. Make sure you only have one key in the vehicle if you have entry and drive.
Old Oct 31, 2016 | 09:01 PM
bcgreen's Avatar
bcgreen
Just tried that and it made no difference. See if this is the correct process? I had the key with me and I started the car. I turned off the a/c and checked the surround FM. I hit SET and 2. Heard the beep and I knew the new settings were locked in. I turned off the car and then restarted it and I could see the check mark go away and the a/c light was on.
Old Oct 31, 2016 | 11:04 PM
Need4S's Avatar
Need4S
Press set and the key icon on the seat memory panel on the door. Assuming you have memory seats. Do this with the key in the ignition and car turned on. If you have keyless entry be sure your key is the only key inside the car.
Old Nov 1, 2016 | 12:39 AM
Todd B's Avatar
Todd B
No, to save the settings to the key so they are recalled when you get back in (unlock), you need to press the button with the key on it. You still press set, then the button with the key on it. In the multi function display you can also turn on auto memory, which automatically saves the settings each time you get out of the car.
The 1/2 buttons do not save the comfort settings, those only store the seat and steering wheel positions.
Old Nov 1, 2016 | 10:08 PM
bcgreen's Avatar
bcgreen
Thank you.
