Trailer hitch
That's in line with what I've seen. Just the parts for the Porsche hitch are $1100. Far cheaper to order with a new Macan then adding it later. Or only search for one that has the hitch.
Checked with a major hitch company here in the city in which I live and their prices is 1/4th the cost of the dealer would charge. The only question I didn't know I needed to ask was about program the Macan for the hitch. Sounded like a lot of work with taking the bumper off and properly fitting around the exhaust. Si in the end they sounded very professional and knew that it was more than a simple bolt on.
I got a Curts hitch from Amazon for a lot less than that. I think that it was in the $125 range. You can also try etrailer which has good prices. I installed it myself in about 2 hours. Could have done it faster but took my time. Install was pretty easy. I am just using it for a bike rack (Kuat hitch mount rack - about the best out there) so no need for the reprogram of the rear electronics.
You need to order the hitch from Audi Q5 or Macan plus a new valance part number 95B807834D1E0 so that it has a cutout for the new part. You can shop the two parts around but avoid shipping as the hitch is considerably heavier than the existing part you will remove. You will need to remove your bumper
What do you think of this statement:
What do you all use your hitch for? The tow rating is so low that I am pretty much giving up on the hitch idea and just going with a roof rack.
I noticed that one of the new hitches I looked into, didn't buy yet, is lighter than the OEM by 10 pounds.
Did you have to do any drilling or was it a direct bolt in?
Not sure, but if I want to buy a piece of furniture or need a new water heater, or take a load of yard clippings to the dump. Not going to use it as a tow vehicle.
Take a look at the instructions pdf in the lower left. There was a little drilling and a little cutting of the rear bumper valence but it was not big deal.
http://www.curtmfg.com/HitchLookup/f...he&model=Macan
