Macan 2014-Current
Sponsored by: HBI Auto
Ground Clearance
Old Nov 26, 2013 | 02:28 AM
Hud99's Avatar
Hud99
Default Ground Clearance
Hi, what is the MAX ground clearance of the Macan with PASM and Air Suspension? How does this compare with the max ground clearance of the Cayenne? Thanks
Old Nov 26, 2013 | 11:31 AM
wwilliams88's Avatar
wwilliams88
They are similar. Motortrend states slightly over 9" ground clearance with the air suspension maxed out for the Macan. I couldn't find anything from the Porsche site to confirm, other than the delta between normal and max is 40 mm (1.57"). In the Cayenne the delta is 2.17" at the rear with air suspension at max (slightly higher in front) for an overall clearance of 9.65"
Just found a couple of other sites that state 9.05 to 9.06" ground clearance for the Macan at max air suspension setting.
Old Nov 26, 2013 | 12:31 PM
jumper5836's Avatar
jumper5836
Macan
Terrain features
Max. clearance between ground and water-sensitive parts (steel suspension) 300 mm
Max. clearance between ground and water-sensitive parts (air suspension, off-road ride height) 285 mm
Slope angle, front/rear (steel suspension) 24.3° / 23.2°
Slope angle, front/rear (air suspension, off-road ride height) 26.6° / 25.3°
Ramp break over angle steel suspension 16,5°
Ramp break over angle air suspension (highest level) 19,0°
Max. clearance between ground and water-sensitive parts (steel suspension) 198 mm
Max. ground clearance (air suspension, normal level) 190 mm
Max. ground clearance (air suspension, off-road ride height) 230 mm
Cayenne
Terrain features
Max. clearance between ground and water-sensitive parts (steel suspension) 500 mm
Max. clearance between ground and water-sensitive parts (air suspension, off-road ride height) 555 mm
Slope angle, front/rear (steel suspension) 26.0° / 24.5°
Slope angle, front/rear (air suspension, off-road ride height) 29.5° / 27.5°
Ramp break over angle steel suspension 20.5°
Ramp break over angle air suspension (highest level) 24.5°
Max. clearance between ground and water-sensitive parts (steel suspension) 215 mm
Max. ground clearance (air suspension, normal level) 210 mm
Max. ground clearance (air suspension, off-road ride height) 268 mm
Old Nov 26, 2013 | 01:07 PM
ISUK's Avatar
ISUK
Old Sep 7, 2014 | 11:05 AM
Hud99's Avatar
Hud99
How does the Macan ground clearance at max with air suspension compare to the max ground clearance of a evoque or Q5 or other comparable vehicles?
