Macan 2014-Current
Sponsored by: HBI Auto
P17D500 pdk code on 2017 Macan Turbo
Old May 6, 2025 | 12:06 AM
Craator's Avatar
Craator
Default P17D500 pdk code on 2017 Macan Turbo
Hi, I noticed my 2017 Macan Turbo (73k mi) started getting code P17D500 after a transmission fluid drain& fill a few months ago. I cleared it to see if it would come back and indeed it did. I don't have any dash lights or any weird transmission-related behavior when driving. Has anyone gone through a similar issue, if so how should I proceed? I read through a few of the threads about the pdk error codes, but many of those seemed to have actual signs of problems past just having the code show up. Also the P17D500 is the only code I'm seeing, mentioning only a mechanical fault. Is it reasonable to think that the transmission is unlikely to be damaged at this point, and perhaps a new solenoid will fix the issue? Thanks for any info.
Old May 10, 2025 | 02:53 PM
siberian's Avatar
siberian
See this:
https://www.macanforum.com/threads/n...faults.183533/
siberian
