Macan 2014-Current
Sponsored by: HBI Auto
Excessive Brake Dust
Old Sep 10, 2024 | 09:23 PM
Ironman88's Avatar
Ironman88
Definitely not PSCB's.
Old Sep 10, 2024 | 09:29 PM
BMinSFL's Avatar
BMinSFL
Originally Posted by bigdstwinturbo
Maybe they are standard brakes. But they still should not be producing that much brake dust.
I figured that as soon as I saw the 19" wheels. It seems normal to me. I have a set of bright silver wheels and a set of dark grey metallic wheels. The latter hides the dust much better, so that's an option. There are also threads here and on Macan Forum about low dust aftermarket pads. I prefer the OE pads for their silence and performance.
At 30k, you are likely due for a set of pads.
My rears were annihilated at 35k with the fronts not far behind. Also ensure a fluid flush has been done recently if the pedal feel isn't great.
Old Sep 10, 2024 | 10:38 PM
bigdstwinturbo's Avatar
bigdstwinturbo
Thank you all for your input. At least they cost a lot less than the PSCB pads
Old Sep 10, 2024 | 11:22 PM
DHL's Avatar
DHL
Another test to see if you have PSCB rotors is to wet them down. If they do not show any rust and remain a mirror like finish, then they are WC coated PSCB rotors. Note, very worn PSCB rotors where the WC coating has worn through will show rust because its the WC coating that has no iron and does not rust. However, unless the car has nearly 70K mi it is not likely WC rotors will have worn though.
Old Sep 11, 2024 | 05:03 AM
BMinSFL's Avatar
BMinSFL
They do. I just did pads for about $220 per axle using all OE parts. At 30-35k miles, you don't need new rotors as long as yours are in normal shape. If doing a DIY, you don't even need the scan tool for the rear parking brake. I used my Milwaukee M12 battery pack as a 12v source to wind back the motor.
What made you think you had the PSCB package? Was it represented at the time of purchase?
Old Sep 11, 2024 | 12:25 PM
bigdstwinturbo
They did not mention the brakes and I figured that the upgraded brakes would have been mentioned on the build sheet if it had it. But then again, we bought it from a Mercedes dealership and what do they know about cars? lol. But the rotors have that mirror sheen... But even regular brakes and pads should not produce that much brake dust, hence my part discordance theory.
Old Sep 11, 2024 | 05:08 PM
BMinSFL's Avatar
BMinSFL
Here's how reflective the PSCB are, its very apparent and significantly more reflective than any typical rotor (not my photo):
Old Sep 12, 2024 | 12:18 AM
DHL's Avatar
DHL
If the rotors are PSCB, then you should be using the OEM pads designed for these rotors. Besides the very low dusting, those OEM pads were designed for the mirror finish WC surface, and probably provide the optimum friction coefficient for those rotors. Using something else may compromise the braking power, not to mention the potential damage to those very EXPENSIVE rotors. You think the pad are expensive, just price a set of WC coated front rotors!
Old Sep 12, 2024 | 05:49 AM
BMinSFL's Avatar
BMinSFL
I looked them up for fun, from my "discount" source at Porsche Parts Deport, $1,847 plus tax each. Still better than full carbon ceramic at $5,967. I think we determined OP does not have PSCB based on spec sheets, wheel size, and a photo of the caliper.
Old Sep 14, 2024 | 11:29 AM
Long Islander's Avatar
Long Islander
I have a 2024 Macan S and have noticed that the brakes produce more dust than my other cars have. I replaced the pads with Akebono or Powerstop Evolution on other cars and have had great results in terms of reducing brake dust. Unfortunately, these pads are not available for a Macan S. I found Ate and Pagid on Pelican Parts for this car. Does anyone have experience with these brands?
Old Sep 14, 2024 | 11:37 AM
Carlo_Carrera's Avatar
Carlo_Carrera
ATE and pagid pads will shed dust just as much as the OEM pads will. You should check rockauto.com. They have a larger selection to choose from.
Old Sep 14, 2024 | 11:40 AM
Long Islander
Thanks. Rock Auto doesn't have any pads for my car. They categorize by caliper color, which is red on my car. They don't have any pads for red calipers.
Old Sep 14, 2024 | 01:43 PM
Long Islander
I found an online seller who carries Hawk that will fit my car. Will Hawk produce less dust?
Old Sep 14, 2024 | 02:46 PM
mark8's Avatar
mark8
I recommend EBC Red Stuff. Stupid name, but great pads. Hawk HPS are also solid pads but can develop some pretty solid squealing. Both are going to produce much less dust though and they have excellent feel for daily driving.
Old Sep 14, 2024 | 04:37 PM
Carlo_Carrera
Originally Posted by Long Islander
Thanks. Rock Auto doesn't have any pads for my car. The categorize by caliper color, which is red on my car. They don't have any pads for red calipers.
Rockauto hasn't updated/cross-referenced the 2024 listings yet. Try the listings for 2023, there are some pads there.
